No not that complaint. Replacing the mirrors there was a ping and the piece holding the glass and the housing seperatrd leaving a broken "c" clip on the floor. Bugger how to replace the c clip, the glass has to be removed to do so! It is very fragile and stuck in really well. Appllied heat to the glass from a heat gun and very very gently and slowly prise glass away with a thin steel rule, patience being the watchword, not too much heat but enough to burn you hand with gloves on, after about 30 mins of very gentle persuasion, glass off new c clip fitted, result. A slightly happier Mark
