Crush Washers
Discussion in 'Supersport (1974-2007)' started by DanSS600, Nov 4, 2022.
  1. What size crush washers will I need to replace if I change the oil filter and clean the gauze strainer?
  2. Did you get an answer? I have some I can measure
  3. If you could that would be very helpful.
  4. Sure,
    1mm x 22ID x 28 outside.
    I will point out that these are not genuine Ducati, but it's the size that fits and I've used them for years without issue. As you can buy them cheap on ebay.
    They are aluminium
  5. Is that size for the sump plug? The oil strainer cover size is shown here as 30x23.2x2
    https://www.corsasbk.com/product/78710091a/
  6. Ah, yes! Sorry that's what I thought you meant.
