Damper Rod Size
Discussion in 'Supersport (1974-2007)' started by DeadWeight, Jan 23, 2016.
  1. Greetings,
    Anyone know the damper rod thread size on the 900 Showa forks? Will shortly be doing the head bearings and installing Wilbur springs in the forks legs and want to make the tool for holding the rods, not done so in the past and they will make the job easier.
    Cheers
    Mike
  2. M10....but I seem to think it may have been M10 fine thread**..........but pushing on a plastic tube is just as good.............or use a length of lockwire.
    ** IIRC Normal M10 is 1.55mm pitch, so Fine should be 1.0mm
    #2 Ghost Rider, Jan 23, 2016
  3. Thanks, not a bad idea that, should have tubing in stock.
    Mike
