749 Datatool S4 Green Alarm Removal
Discussion in '749 / 999' started by Penfold, Jul 22, 2014.
  1. As the title says I'm getting rid of the piece of cr@p from my 749 as its killing my battery and giving me all sorts of problems.
    What is the best way to go about it?
    I know I should trace the wires back to the loom one at a time and disconnect the alarm ones and reconnect the loom ones by soldering and heat wrap them.
    Do I have to put the alarm in service mode? How is this done?
    Also whilst talking to someone about this who has removed one he mentioned a pin code for it or it will immobilise my bike totally. What's that all about?
    Cheers in advance.
    Penfold
  2. The alarm/immobiliser should not interact with the ECU or Dash. Unless you want to keep the alarm and use it for something else, why do you need a pin number? Have a chat with The Bike Alarm Man : | Motorcycle Alarms and Advice. he may be able to give you a clue to what to do.
  3. I have used him, hes a good chap and fitted a replacement alarm for me when mine went mad.
    Recommended guy and you can tell he really knows his stuff. :upyeah:
