hi diavel owners. I need the exact distance in millimetres between the hole centres for the exhaust heatshield that looks like that thanks very much
Have measured heat shield 84mm centre of bolt to centre of bolt is what I make it. That's on a full Termi system, assume it's the same heat shield as standard, looks like your pic.
What can I say, garage isn't linked to the house and it's been raining... I've got the standard system, I'll check in a break between clouds.
just run really fast. im sure youll cover the 200m to your garage block on you stately home easy. ot just take the golf buggy thanks
Ha, took the golf buggy to the jetty then the speedboat as a short cut across to the western shore of the pond, well, more of a lake really then got aboard the palanquin and got the 20 servants to carry me over to the east wing of the garage, took the lift up to the 12th floor then rode my carbon Segway across to bay 1342, took out my Gucci calipers and got 83.5mm
