Taken off my recently sold Gen 2 Diavel. This is a black non see through touring screen that includes a small cockpit dashboard fitted with a satnav/phone ball mount and a double usb power socket that also shows a readout of battery condition. Only the ball mount is included, THE X CLAMP RAM MOUNT IS NOT INCLUDED. The 12v feed for this can be found just behind the headlight. £60 collected North Shropshire or £10 postage.
Hi did this sell? also does this need connecting to the battery or is there a 12v connection closer on the diavel? thanks
Hi, I still have this for sale. If you pop the screen off and have a furkle around on the right hand side in the exposed space you should find an unused connection in the wiring. It will be blanked off from the factory. The USB charger has enough wiring to reach this without needing to run a wire down to the battery and it only comes live when the ignition is on. The screen divides opinion over its looks but it keeps the wind blast off your body and the worst of the weather off your phone/satnav if you choose to mount one.
