DP mirror question
Discussion in '848 / 1098 / 1198' started by Maccaa, May 10, 2012.
  1. Evening girls and boys,
    I am thinking of buying some DP mirrors to put on my 1198 as it sounds as though some of the vibration is reduced, does anyone happen to know if you can use the original " extensions" or should you not use them in conjunction anyway?
    Thanks
    Maccaa
  2. If you look over your shoulder instead, you do away with all the vibrations ;)
  3. I'm sure they do...as the footprint of the DP ones share the same rubber as the standard one.
    So if the bottom of both is the same then it should match up with the moose antler extenders.
  4. Moose antlers ! how very dare you.....:smile:
    I shall be using the Ducati supplied units. :upyeah:
  5. Don't forget to post a picture when you've done it Maccaa! :biggrin:
