Does anyone have a pdf copy (or a link to) the fitting instructions for a 1199 tail tidy? Bought a used one but it has no accompanying instructions with it. Cheers. Ian
Hi, I fitted mine after watching you tube - search best 10 things to fit to your panigale . You will need a extra long 4mm long Allen key to reach the bolts inside the tail unit, if not you will have to strip the seat unit down. It's easy when you see it / about 15 -20 mins work.
