749 Dp168 Öhlins Damper
Discussion in '749 / 999' started by Tom Brands, Apr 4, 2016.
  1. Hello,
    I was replacing my stock steering damper with a DP168 the other day. When taking off the stock damper i think i have lost one of the mounting pieces.
    I have a long and a short hex screw. If i recall correctly the long screw mounts to the frame on the right side and the short screw mounts to the yoke/steering lock bracket.
    But the short screw isn't long enough to pass through the yoke and and fasten to the steering lock bracket.
    Also i seem te be missing a rubber washer o-ring to mount between the damperbracket and the yoke.
    1. Can i switch the long and the short hex screws safely?
    2. Can anyone tell me what part numbers i need to order a new o-ring and maybe screws?
    Thanks!
  2. You can Google/download a parts PDF which will show an exploded diagram of all the bits.
  3. The longer bolt goes through the top triple, shorter one is for the frame mount. The O ring is part nr. 886.5.014.1A.
