Any of you guys use the draggin k-legs under normal jeans?, Was planning a pair for just short runs and knocking about, Whats your thoughts on them? Advice on sizing/ fit would be good. Cheers Jack
As no one has replied about the leggings, I thought I would mention that I have the top and it's kinda like a light sweatshirt in weight and thickness, but a very open weave so you can see light through it if you hold it up to the light. This means that when you are moving, air will flow through it very easily. When stopped, if it is about 20C +, you will feel hot I guess. Assuming you dont wear skin tight jeans, they should fit under. They are a bit stretchy, so are a forgiving fit. Tighter is better I reckon. Hope that helps
My personal opinion on Kevlar jeans is that they are no good without under armour anyway. This is from the experience of staring at my exposed kneecap after a 50mph off..... Whilst I am sure they are better than normal jeans, they are not what I would call protective.
That's got to be horrible Jolley when you put your faith in products like that. I have a pair of Resurgence jeans that look like normal jeans and are more comfortable than my normal M&S jeans, but the benefit is that they are CE2 rated. Even my Dainese leathers are not CE2 rated. I dumped the armour and wear forcefield CE2 net knee tubes directly on my legs so they stay in place, and hip armour in the pockets which are tight enough not to move around. They have a slide rating of over 10 seconds, and from memory of seeing the certificate, the german TUV testing of them actually had a 20 second slide result on them. Quite impressive for jeans that look normal when worn. I dont have that same faith in the Draggin K stuff, but depends on your use and intent.
