1199 Ducati 1199 Panigale Termignoni Db Baffles Wanted
Discussion in 'Panigale' started by garyjaffa, Jun 29, 2015.
  1. Ducati 1199 panigale termignoni db baffles wanted for bike MOT this week!!!! (Even If I could borrow a set would be brilliant!!)
    Thank you
  2. Find a friendly MOT station and they shouldn't fail you. Ask on here for ones local to you.
    I would say though that the one thing they might well fail a bike with is if they can read the 'Not for road use' typed on any can. You can cover this up with a piece of tape as they are not allowed to remove it.
  3. Ah ok its a full system I have.
  4. Do not fret, so long as the system doesn't leak, it will pass. The MoT does not do a Db test, just a 'reasonably silenced' check. This is tester dependant, not an official figure. Do not confuse Law with MoT testing. One is Law, the other is a safety check.... the tester is not allowed to test the Law as he is not qualified so to do, nor is a mechanic a Professional.
  5. Just put mine through its first Mot with full Termi system, no problems , Ian Murray Ducati ( Edinburgh )
