Anyone have any knowledge on the 848 not starting? It was working fine on Friday but Saturday morning it wouldn't turn over. I'd appreciate any help thanks.
also before you do anything else. if you have a decent set of jump leads connect the negative battery pole to good earth on the engine bearing in mind the casings are lacquered and the exhaust will scratch. that will eliminate an earth issue.
