Ducati 999 / 749 EOBD Error Codes
Discussion in '749 / 999' started by Rob, Mar 21, 2012.
  1. Ducati 999/749 EOBD Codes
    Listed below are the Ducati error codes for the 999/749 series which are very handy to know...
    If your stead decides to create an error and then flashes her yellow warning strobe (the EOBDlight) then follow these steps....
    1) Turn the ignition to 'OFF' (Whilst stationary that is...)
    2) Depress and hold the left hand instrument panel button
    3) Turn the ignition to 'ON' whilst still depressing the left hand button
    4) You should then see the error codes displayed
    5) Make a mental note of the codes and cross reference with the following list.........
    ERROR CODES
    1.1 = Throttle Position Sensor (TPS) Disconnected
    1.2 = Throttle Position Sensor (TPS) short circuit to earth
    2.1 = Pressure Sensor short circuit to power supply
    2.2 = Pressure Sensor shorted to earth
    3.1 = Water Temp Sensor shorted to power supply
    3.2 = Water Temp Sensor shorted to earth
    4.1 = Air Temp Sensor shorted to power supply
    4.2 = Air Temp Sensor Shorted to earth
    5.1 = Battery Hi
    5.2 = Battery Lo
    10.1 = Horizontal Coil shorted to power supply
    10.2 = Horizontal Coil shorted to earth
    11.1 = Vertical Coil shorted to power supply
    11.2 = Vertical Coil shorted to earth
    12.1 = Inj1 shorted to power supply
    12.2 = Inj1 shorted to earth
    13.1 = Inj2 shorted to power supply
    13.2 = Inj2 shorted to earth
    14.1 = Inj3 shorted to to power supply
    14.2 = Inj3 shorted to earth
    15.1 = Inj4 shorted to powersupply
    15.2 = Inj4 shorted to earth
    16.0 = Pump Relay
    17.1 = L/H Fan shorted to power supply
    17.2 = L/H Fan shorted to earth
    18.1 = R/H Fan shorted to power supply
    18.2 = R/H Fan shorted to earth
    19.1 = Starter Solenoid shorted to power supply
    19.2 = Starter Solenoid shorted to earth
    30.0 = ROM/Eprom error
    34.0 = Signal Panel Sensor
    36.0 = Speed sensor
    37.0 = Immobiliser (transponder)
    37.1 = Immobiliser (antenna)
    37.2 = Immobiliser (instrument panel serial driver)
    37.3 = Immobiliser (serial cable disconnected)
    37.4 = Immobiliser (ccm serial drive)
    37.5 = Immobiliser (key not recognised)
    37.6 = Can Line error
  2. Hi everyone. itching to get back out on the 749r 2005 Ducati . Got a problem bike not starting very well . Low battery level while it's been on trickle charge Err codes 10.1 and 11.2 . I've checked one site they mention spark plugs probably need changing . Engine management light on all the time aswell .
    Just thought I'd check the forum aswell .
    Hopefully long ride out tomorrow ️️
  3. Could be the pesky fuel pump relay.
  4. Cheers Ricky will look into that cheers ️️
