I have fitted the above to my Diavel.The originals had compression and rebound damping adjustment on each fork.The Andreani has compression damping on one and rebound damping adjustment on the other.I understand that but what about the original compression damping adjusters on the fork bottoms,what should they be set at .
My 796 Andreanis has compression and rebound on different legs , but the Diavel was unchanged from std adjustment as far as remember Compression on the leg , rebound on top . You may have a different / later setup , but it’s unusual
