Ducati Forum 470Four Bike of the Year 2013 - entry thread
Discussion in 'Ducati General Discussion' started by mattmccabebrown, Dec 9, 2013.
  1. Welcome to the 2013 Ducati Forum Bike of the year contest. Last year, Desmohog won the 470Four Trophy with this fine example
    To keep it simple the rules will be very similar to last year
    • Ducati only
    • Only 2 pics of bikes per entry
    • Please give a nice overview of any mods done or say a few words about your bike(s)
    • No limited to number of bikes entered, Ie if you own two Ducati's you can enter both
    • Entries will be allowed up to and including 31/12/13, voting through January with the winner announced at the start of February 2014.
    We will try and sort out some decent prizes and will get the 470Four Trophy (made by Duc904red) off Desmohog which will be presented to the winner.....hopefully :smile:
    Please keep this thread clear of any discussion on the entries (just keeps it tidy - we all know I like tidy) and direct all discussion to the Bike of the Year Sister thread
    http://ducatiforum.co.uk/f16/ducati-forum-470four-bike-year-2013-discussion-thread-18107/
    On or around 1st January, I will open up another thread for the voting
    Good luck and get entering
    #1 mattmccabebrown, Dec 9, 2013
  2. My shed built Radical Pantah!
    Built by my own fair hands from an Aluzzurra and a 750SS. The only thing I didn't do was the paint.
    As people are listing modifications, here goes. Basics are I took the Pantah chassis and cut the back end off, including the twin shock mounts. I then set the geometry and welded the mono-shock mount into the Pantah chassis. The front end was removed and a USD front end was fitted, with single disc to reduce unsprung weight. This is plenty good enough due to a light bike. The motor was stripped and rebuilt as stock. The carbs are PHF36's with alloy bellmouths, with a home made rear inlet manifold to position the carb within the frame rails. The battery was relocated to behind the headstock, and a modified loom was made and fitted to re-position all the electrics under the tank to keep the look clean. Nothing electric can be seen apart from the odd lead from pick-ups etc. I fabricated a new fairing frame to allow the new fairing to be fitted along with re-positioned 750SS clocks, and an auxiliary power supply for sat navs etc. (It's built to be used, I rode it to Spa last summer). The exhaust is stock with cut down carbon cans. Adjustable clip ons are fitted, and the pegs are mounted to suit me, but can be adjustable if required. I can move it about to make it more tourer friendly, or track ready. There is so much more but this is the real basics. This all sounds pretty simple, but is the result of 100's of hours of head scratching, cutting, welding, re-cutting, re-welding, more head scratching etc, etc, in my workshop. I'm glad people like it!
    #2 nuttynick, Dec 9, 2013
    • Like Like x 20
  3. 2013 - 1199R RAYMOND ROCHE RACE rep trackbike
    This bike is meant to be as good looking and well working as she can be for intense track use
    Sort of make the sensible mans RS
    I'm over the moon whith how she worked out in the end. Big thanks to all who helped her come to that.
    Just to repeat what ' done to the bike:
    2013 - 1199R Raymond Roche 001/001 – project items
    1. 2013 – Ducati Panigale 1199R – Bologna Motors / Ducati Herzele
    1. Termignoni EVO Titanium mufflers
    2. Termignoni PRO manifold + mapping – DP
    3. MWR race airfilter
    4. Roby moto 52/58 triples
    5. Ohlins FGR100 (new) SBK spec - front forks
    6. Made to order front axel
    7. Made to order front mudguard holders
    8. Made to order speedsensor holder
    9. Valtermoto clip on holders
    10. Carbon clip ons
    11. Brembo 320MM SBK 6 mm rotors
    12. Brembo 108 mm P4 – 32/36 endurance monobloc callipers
    13. Brembo GP spec master clutch cylinder 18x19 mm
    14. Brembo GP spec master brake cylinder 19x18 mm
    15. Brembo P2 – 34 2 piece billet rear brake caliper
    16. Brembo Z4 brake pads
    17. Trax racing brakelines front
    18. Made to order fluidreservoir holders
    19. OZ Cattiva Magnesium 16,5 inch wheels
    20. DP – TCS spinunit at wheel
    21. Pirelli 16,5 slicks Diablo Superbike 120/75 and 190/65 - SC2 compound
    22. Sprocket carrier + 42 & 43 T sprockets
    23. Removal of the DES on the TTX rear shock
    24. EMC² setup and geometry analysis
    25. DP race rearsets in classic shift pattern ( 1 down – 5 up)
    26. BBS – TCS/ABS settings ecu with 16,5” Pirelli SC2 settings – Moto Puro , Holland - Ducati Corse
    27. Bolts and bits – Titanium – Pro Bolt
    28. Carbon Fuel tank – Carbonvani
    29. Carbon race fairing - head, left side , right side, belly pan - Ilmberger
    30. Carbon race seatunit – Ilmberger
    31. Carbon inner radiator fairing – Carbonvani
    32. Carbon inner side pannels – Carbonvani
    33. Carbon sprocket cover
    34. Carbon headfairing + dashcover - SIGL
    35. Carbon subframe covers – Conquest Carbon
    36. Carbon front mudguard – Carbon King
    37. Carbon chainguard - Carbonworld
    38. Carbon clutch cover full right size ( 13,8 components)
    39. Carbon case cover left side
    40. Samco hoses
    41. RS style filler cap
    42. STM race starter switch buttons (R – 2)
    43. STM dash control switch buttons (L – 4)
    44. Progrip
    45. Stompgrip
    46. DP racing seat
    47. Racing screen
    48. Raymond Roche theme design - Stephen Toal
    49. Raymond Roche strickering system
    50. Full paintwork – Paintatelier – Alstare painter
    51. Full strip and build up – friends and mates
    52. Dyno runs and mapping and general maintenance – Ducati Gent
    53. DP rearstand
    54. DP frontstand – milled pins to accommodate FGR’s
    55. Tyrewarmers ( 2 sets)
    56. Pitkit – Beta + miscellaneous
    57. Schubert SR1
    58. Daytona EVO3 – GP boots
    59. Held Titan gloves
    60. Damen Race suit tailored
    Planned 2014 winter job ( ordered)
    Moto Rapido engine blueprint
    Corse SBK 2013 V2 +300MM manifold
    Race radiator ( CORE 35MM)
    AIM telemetry sensor set.
    Pro shift PS3 closed loop blipper system
    Race Seat personalised race seat ( 2CM higher over DP race seat)
    • Like Like x 31
  4. My Monster 695. Totally standard with the exception of the Sil Moto pipes, heated grips and some hand guards. Bought only a few months ago to get me to and from work
  5. My 1098s. Mods included a full Barnetts clutch system with an Evotech open clutch cover. Red Samco coolant hoses. A smattering of carbon fibre including a lovely matte black belly pad and from mudguard from Steve at Conquest. Integrated rear tail light with a tail tidy. ASV long levers. Stomp grips and a pair of Metal Tech racing rearsets
    • Like Like x 15
  6. My 1996 Ducati 600 Supersport.
    Bought this year as a first bike after passing my direct access at the young age of 48, not a great first bike, as its a pig to ride in slow traffic, but lovely to look at and great to own!
    28,000 miles, completely standard, un-restored, un-modified and now becoming rare as there now only a handful that are regularly taxed and used all year round.
    • Like Like x 11
  7. My 1999 Monster owned from new and originally a M600 Dark.
    It currently has a 1994 Ducati SS engine (Hi-comp pistons), 888 rear wheel (190 tyre fitted), 916 fully floating front brake set up and master cylinders to suit, Fire custom headlight, alloy swing arm, M620 carbon exhausts, black anodised SS front forks.
    Granted Kitty Brooker should be behind the bike but there was an explosion .....
    Yorkie
    • Like Like x 14
  8. Oh go on then...
    Posting only cos I luv the bike so much I'd make it the winner myself :biggrin:
    My 999s 'italia'. Once a black Mono Nero.
    • ProTwins race-seat
    • Adjustable levers
    • TechSpec Gripster tankpads
    • MPL slipper clutch
    • Cheap HongKong-sourced fairings, painted by Larry at Illusion Racepaint
    • Serviced / set-up by Rich at LouigiMoto
    • Ridden (mostly lazily) by me
    • Like Like x 13
  9. This is my entry & after a years worth of upgrades!
    Ducati 848 R
    MODIFICATION LIST:
    CARBON FIBRE:
    Chain Guard
    Clutch Cover
    Engine Cover (Left Side)
    Engine Cover (Right Side)
    Exhaust Heat Cover (Side Pipes)
    Exhaust Heat Cover (Under Seat)
    Fairing V Guard Cover
    Front Fender (Custom Painted)
    Front Sprocket Cover
    Heel Guards
    Instrument Guard
    Key Guard Cover
    Meter Visor
    Ram Air Panels
    Rear Brake Pump Guard
    Rear Tail Hugger
    Side Panels
    Seat Cowl Cover
    Swing Arm Cover
    Tail Vent Inserts
    Under Tail Panel
    Upper Fairing Stay
    CNC:
    Front Wheel Sliders
    Rear Wheel Sliders
    COMPETITION WERKES:
    Licence Plate Delete
    CUSTOM:
    Billet Lightweight Cam Belt Rollers (Anodized Red)
    LED Rear Turn Signals (In Vents)
    LED Tail Light with Blaster
    D.I.D:
    Gold/Black Chain
    DUCABIKE:
    Adjustable Link Bar (Gold)
    Alternator Cover (Gold)
    Clutch Slave Cylinder (Gold)
    Damper Bracket (Gold)
    Frame Plugs (Gold Contrast Cut)
    Levers (Black/Gold)
    Rear Sets (Black/Gold)
    Rear Sprocket Flange (Black/Red)
    DUCATI PERFORMANCE:
    Front Sprocket (14 Tooth)
    LED Mirrors
    Lightened Fly Wheel
    Rear Sprocket (Black)
    Slipper Dry Clutch (Red with Gold Caps)
    G.I. PRO:
    Gear Indicator
    NICHOLS:
    Adjustable Triple Tree
    ÖHLINS:
    Forks FGRT-819
    Rear Shock TTX-MKII/DU-931
    Steering Damper SD-031
    OZ:
    Piega Wheels (Gold)
    RIZOMA:
    Handle Bar Ends (Gold)
    Lux Grips (Black/Gold)
    Next Fluid Tanks (Oval Gold All 3)
    Oil Plug (Gold)
    Timing Belt Cover (Clear)
    SARGENT:
    Gel Seat With Gold Stitching & Italian Flag On Both Sides (Custom)
    SAMCO:
    Silicone Hoses (Red)
    SPEEDYMOTO:
    Billet Water Pump (Silver)
    SICK-HID's:
    Bi-Xenon Projectors (Red Demon Eyes, Blue Halos, White Eyebrows)
    TAMBURINI CORSE:
    Quick Release Fuel Cap (Nero Special Edition Carbon)
    TERMIGNONI:
    Full 70mm Exhaust (Polished)
    #9 Sinister, Dec 11, 2013
    • Like Like x 20
  10. Doesn't have the big budget or carved from the solid appeal of some of the great bikes already on this thread, but I'm proud of her..:smile:
    The story began with a very strange ebay sale. The engine (848evo) along with the TB's , air box, stand, headers, injectors and loom, were listed with and end time of 04.17am.
    I decided to put a cheeky bid in before bed and let the ebay/bike building gods decide!
    Anywho...No other bids were made and the motor with all bits became mine for the sum of £800.
    The scope was to build a cheap(ish) track bike, I have only participated in one track day before, but decided to give it a go.... Build it and they will come...:wink:
    Spec is fairly humble.
    848evo motor
    848 forks
    1098s brakes and M/C's
    748 frame
    Blue Peter air box
    Modified 848 loom
    848 LCD dash and ecu (Thanks to Chris for the flash:upyeah:)
    Sigma wet slipper clutch
    Modified 1098/848 sub frame with fairing/seat.
    Cheapo ebay track fairings
    Nice chap on the forum rearsets
    Stock 848 exhaust (for now) with lambdas and servo removed
    848 rear wheel
    Anchor Brembo front wheel (for now)
    All work carried out by me, 'cept the ecu flash and sub-frame welding.
    Vote for Pedo... No, that's no right..He's been locked up...:eek:
    Vote for Pedro! :biggrin:
    • Like Like x 18
  11. Well here's my 900 Mk1 Superlight , its number 110 it made Practical Sportsbikes August issue and its been a bit of a hoot to restore and ride so much so that I've bought another MK1 to restore #171
    Ducati 900 Superlight Mk1 #110
    Built 24/3/1992 Registered 05/03/1993
    Period Mods That came free J
    Baines Racing Twin oil cooler set up, Full Skorpion (Akrapovic) Stainless / Carbon “spaghetti” system (High BHP version)
    Arias High comp pistons, Dynojet Stage 2 running K&N air filter.
    Simons Mods 2012 /2013
    900 SS IE rear shock raises the rear end by a few mm, Dyna mini coils with Taylor racing HT leads, Oberon clutch cylinder
    Renthal rear sprocket , Tsubaki X ring chain, Electrex Regulator/Rectifier,
    Full strip down.
    Frame and wheels powder coated by Redditch shotblasting & Powdercoating, New wheel bearings , steering head and swinging arm bearings.
    Engine cases stripped and re painted using etch primer and techcote Satin black and Simoniz aluminium engine enamel.
    Wiring loom checked and modified for use with the Electrex regulator rectifier.
    Earth and starter cable upgraded to heavy duty items, earth runs to one point on frame unlike the silly lead that runs from the engine to the Right hand footrest.
    All fasteners replaced with Stainless (non load bearing ) or Zinc (load bearing)
    Exhaust valve guides replaced , all valves re ground head re shimmed ( Thanks to Tim at Motovation Cheltenham)
    All gaskets and seals replaced, base gaskets sealed with Three bond.
    All brake calipers stripped down and cleaned , new pads fitted.
    All well nuts replaced.
    Cambelts replaced
    Fuel filter and tank seals replaced
    New genuine Ducati clutch pack set , basket was fine.
    New Clutch release bearing, New clutch springs and caps.
    Darren’s 470 Four 600ss Flywheel mod
    bbb fabrications Footrest adjuster plates and frame brace.
    • Like Like x 17
  12. Heres mine
    Was a standard blue and white s4r, not no more,
    Full history, 2 black keys, 1 red key and key card
    Immobilizer fitted
    QD exhaust
    Custom clocks (originals reworked)
    Kawasaki quad bike headlamp,( now wrapped in red and black contravision wrapped lenses) pics to follow
    Headlamp brackets wrapped in satin black (pics to follow)
    Powder coated wheels in black with red stripe,
    Powder coated red frame
    Rear subframe chop
    Rear seat re worked to make single seat pod
    Brand new rear seat pod section in red with black stripe
    Brand new tank in red with black stripe
    Black harris quick release fuel cap
    New black short levers
    Rear carbon hugger
    Optimate wires fitted
    Carbon under tray
    Carbon spaced off clutch cover
    Shortened front carbon mudguard
    Different mirrors
    relocated number plate under seat
    Carbon wrapped standard bars, (not ones in picture,pic to follow)
    New indicators
    Red hoses
    Things to do,
    Strip and powder coat in satin black, forks, and all clamps, rear swing arm and anything else silver,
    [​IMG][/URL]
    [​IMG][/URL]
    needs a new home, wink wink
    #12 Monsters4r, Dec 13, 2013
    • Like Like x 13
  13. There are some awesome bikes here - Mine cannot compete!
    '04 749 Dark - Carbon fairings and a few other bits
    She has achieved some awesome things this year though - How about 2000 miles in 4 days and the Stelvio pass in a foot of snow??
    • Like Like x 10
    She's gone now....but this is the best bike I've owned, the one I've done most to but unlike some its mainly bolt on rather than build. Mostly to make the bike netter rather than fancy-dan looking
    ohilns forks
    ohlins damper
    ohlins TTx rear
    CJS custom set up, 139hp
    Polished system
    Akros
    Black instead of red wheels
    carbon seat
    carbon swingarm cover
    sigma slipper clutch
    few titanium trinkets here and there for bolts
    few other little carbon bits too
    and being ridden how it should be...
    • Like Like x 11
  15. Here's my 1198s, ever since I watched Troy bayliss dominate and win the wsbk championship in 2008 I always said I'd get one. It's my first ducati superbike and I'm in love! It has the following fitted;
    slash cut termi's
    Most of the ducati performace carbon
    red titanium screws
    asv long leavers
    JHP open clutch cover
    JHP slipper clutch
    JHP clutch master cylinder
    nemisis traction control
    ducati performance preload adjusters :)
    • Like Like x 10
  16. [​IMG]
    • Like Like x 10
  17. [​IMG]
    My 1098 in red now
    when i first picked it up and before a few mods
    Termis
    rearsets
    D-Zus fairing bolts
    tinted screen
    kurvey gurl fasteners
    new clutch cover, DPP springs
    DP seat
    tail tidy and Manx plate
    a few bits of carbon
    evo tech levers
    polished pipes
    #17 wantz1, Dec 15, 2013
    • Like Like x 7
  18. Just in case I have to remind you all of the best looking bike out there
    :smile:
    • Like Like x 8
  19. sf pic.jpg One for the ladies
    More carbon than a HB pencil at a sharpening party and tooned by Wilf at MR
    #19 Char, Dec 15, 2013
    • Like Like x 9
  20. a couple of the front, not the best settings for a photo
    [​IMG][/URL]
    [​IMG][/URL]
