848 Ducati Performance Steering Damper
Discussion in '848 / 1098 / 1198' started by aleuts, Apr 30, 2015.
  1. I don't suppose any one has a copy of fitting instructions for a Ducati performance steering damper by gubellini?
  2. Aren't they similar to the Dan Kyle ones? Thought they just bolted on to the key guard bolts?
  3. Thanks for the link. From what I understand you either have to have a special key guard or cut your current key guard to install it. Problem is as I have no instructions I'm no sure how or where to Make the cut to fit it.
  4. I read on that forum some time ago that you needed to cut a bit out of the key guard. Can't you fit it without the key guard then measure up best you can then cut the key guard to suit. Bit of a ball ache but might be the only way withou a template or drawing.
