Ducati sat nav connection
Discussion in 'Multistrada' started by PHILLIPO, Jul 24, 2013.
  1. Is there a socket hidden somewhere up front for connecting a sat nav to. Or do I have to run cables straight to the battery? 2013 multi abs.
    Thanks
  2. Yes. Under the left front fairing. the black bit. Just 2 screws using the smaller of the Allen keys in the tool pouch.
    Not so much a plug as a pair of power leads slaved to the ignition. Doddle to fit. Check out AndyW's MTS Info page for pics etc.
  3. It is actually a connector fitted with flying leads. That way you can unplug the connector, solder the loose wires to your power lead and do all the threading through the bodywork and then then plug it back in.
