Any one fitted an O2 open loop gadget to there 1200 Multi? I've added a link of eBay FYI. DUCATI DIAVEL MULTISTRADA 1200 ECU OPEN LOOP O2 MANIPULATOR EXHAUST SLIPON | eBay Can / Do they work after your bikes been remapped? or will that weaken the fuel air mixture to much? Things that usually appear to good to be true normally are!!?? Any experience anyone? Cheers Chris
These are the alternatives to Fat Ducs, I believe these show alter the outside temp reading . If you have had a re map then this type of thing should not be needed ?
These do work off the air temp sensor, making the bike run richer by making it think its in cold air. They also bugger up your outside temp display as well I would go with the fatducs or better still a remap
