End can
Discussion in 'Multistrada' started by psalliss, Aug 4, 2013.
  1. I know this has probably been asked to death but what cheap options are there for just an end can for a 2013 multi other than the termi end can?
    thanks
  2. I don't think folks with 2013 Multistradas do cheap :wink:
  3. The stubby carbon Termi if mating to standard headers/CAT. Otherwise it's full or composite system for you laddie ;-)
    I know this is a 2012 but I have this fitted to the standard cat which should be identical to 2013 model. IMO looks a lot better although there is very little sound difference. Only issue I have found so far is that you must use a 65 profile tyre, the 60 hits the can. Andy
  5. What about the Leo Vince, miv or gpr end cans. Can they not be used with existing centre section
