Engine Check Light On
Discussion in 'Technical Help' started by Mojo, May 28, 2020.
  1. Hi guys and girls.
    I have a 2013 panigale R,Yesterday I went to start the bike up getting it warmed up for a ride,noticed the engine check light and red engine light remains on, and wont go out.All my local duc shops near me seem closed.im in Surrey. please help me someone,???
    Regards
  2. No idea sorry, but we're listening if that helps ...
  3. Try disconnecting the battery overnight. Reconnect and start the bike, you could get lucky and it's just a fault code gremlin. Worth a try if you're no dealer is available due to lockdown.
  4. Does it sound ok?If so then possibly Oil pressure switche or even the oil pressure switch wiring has disconnected??
  5. Hi
    Thanks for your reply. When I was warming the bike up it sounded like the engine was on limited revs,like it was ready to cut out.ive got it booked in at Snells ducati in Alton on 22nd June,that's the earliest they could fit me in.
  6. Good luck, nothing to do with my ideas then, let us know how you get on.
