749 Error Code P0352
Discussion in '749 / 999' started by Duc748, Mar 6, 2023.
  1. Hi to all. After doing a diagnostic test the code p0352 Ignition coil B Primary/Secondary Curcuit Malfunction is showing. Looking for advice on this issue.
    Thanks in advance for all help
  2. Is this a stored code and no MIL on the dash
  3. Any error related to coils or injectors on the 749/999 is worth solving by fitting a new injection relay. Give the connector a good clean to. It's tucked away down below and behind the battery cover.
  4. I echo what Nelly says about the relay. It should really be a service item.
    These stored errors can be linked to times when the bike has failed on the button. Easily cured by beefing up the cables to the starter motor. Also protects the life span of the sprag clutch.
