Yo all As you know new Monsters have a stacked headlamp which quite frankly is cr@p, dip beam sharp cut off just in front of the wheel ( and ive adjusted it up as far as i can ) and full beam very wishy-washy and no penetration or power to the light. Has anyone found a fix to this problem e.g. HID, zeon, ect that works well and is easy to fit. Ive noted that the reflector is very shallow looking and the bulbs are close to the lens which looks to be plastic which is a concern if a new set-up gets hot. Chears
