Im going to put on a pair of evotech engine crash bobbins on my Multi, the instructions recommend tightening to Ducatis recommended torque. Can anyone let me know what the figure is?
From the workshop manual: Frame-plate adjuster retaining screws M10x1.5 50* GREASE B Frame to engine front retaining screw with special nut M12x1.5 60* GREASE B Frame to engine rear retaining screw with special nut M2x1.5 60* GREASE B Adjuster retainer M 20x1 80* GREASE B Rear subframe RH and LH to crankcase lower retainer 10x1.25 42* LOCK 8 That's in Newton/meters, and I think the engine bolt you change for the crash bobbin is the front retaining screw at 60 N/m. +/- 10% tolerance.
