Hello all, Just registered here after Ducatisti seems to have permanently dissapeared sadly. Just bought some carbon Termi's from ebay that came off a 94 916 and fitted to my 2001 996Bip. They fit except they have a significantly smaller circumference so the straps from my standard 996 cans are too big. Does anyone have any that would fit, know how I could find some or have any advice on it generally? Cheers.
Any good to you? PJ Engineering - Products Page - Manufacturers & suppliers of High Temp. Carbon Fibre, Stainless & Titanium Tubes and Performance Motorcycle Exhaust parts in Lincolnshire, UK AL
I've found an older thread where someone had the opposite problem and needed larger straps so have pm'd him to see if he's got the shorter ones. However, just measure circumference as 355mm so the 110m diameter straps may just do the job if needs be. Rather not fork out another £40 though, oh and I guess I need an eprom for ~£30 too.
Later original exhausts are a larger diameter, prob noise or emissions related. As per Arquebus' comment but I would use a local engineering shop, not car or bike related and just take a can in, should be fast and pretty cheap. Or there is always evilbay........
