I have some older kit which was fairly cheap (sub £200) and isnt that waterproof even with all the liners in. So been thinking (after the waterproofs thread) does a waterproofing spray, reapplied fairly regularly, make jackets as good/nearly as good as the mad £600+ rukka product? Not likely to be used for commuting but leisure rides and potential full days out I have got used to riding with leathers and an oversuit but on the Multi would be nice not to bother with the additional kit, which means you have to pull over and kit up, and have a set which are just fairly warm and dry. also same with gloves, never found a sub £100 set which are waterproof for more than 100yards
If I was commuting I'd go buy the best kit, all the patrols etc did have, but its a leisure thing and pocket money for leisure stretched easier to a £20 tub of proofing than a grand on a coat.
The waterproofing spray does work, but would have to be applied each year, also if the stuff you already have is goretex, then that needs a yearly wash to clean the fabric. Personally i dont like goretex gear, i have wet weather gortex gear at work, and that wont last an 8 hour shift in rain without leaking, i sold my HG goretex gear for some Lindstrands which has a waterproof liner, lots easier to look after.
im not taking the piss here but i bought a set of waterproofs for when im mountain biking...they were dirt cheap (about £20) and ive been out in torrential rain and been drizabone..the only dampness on the inside is honest sweat..i even wore them over my leathers the other day when i rode that new bike back...again, bone dry when i got home. No insulation, no frills, no problem.
Yep I do the same with my one piece or trousers and Mountaine goretex jacket. But its more clobber to carry.
my leathers have a goretex lining but I also use Gaerne Waterproof keeps them supple and water resistant, stops it soaking in and making them very heavy. My "Bikers" gloves warm and dry ....commuting 2hrs a day in torrential rain .....just a pain if your hands get wet before you put them on.
Been the cheap route, and now have Rukka jacket and trousers. I wouldn't go back now I'm afraid. You get what you pay for.
Bradders your 200GBP is not cheap option sorry. Frr cheap I buy pair of over-trousers for 29.99 and a jacket for 39.99. Both work well for up to 1h commute, after that get slightly moist here or there. Torrential rain maximum 20 min. Saying that last entire winter of commute. I also one time had a expensive Rukka. Very good but lasted 2y before seems started leaking. Math I did suggested stick to cheapest stuff for commute.
Top tip if you want REALLY waterproof kit - Quite a lot of "waterproof" kit is designed for walking around in. Buy stuff that's designed for sailing/yachting : the difference is that stuff is desgned to be waterproof when you're sitting down - subtle but crucial difference... I have some Musto MPX goretex stuff for work and it is absolutely 100% waterproof no matter where I wear it - at sea, on land, on a bike... Better than any bike kit I have ever had.
I like this explanation from moto legends. The Meaning of Waterproof Question: When does waterproof not mean waterproof? Answer: When the word is applied to motorcycle clothing! Obviously, we’re being a little glib here, but there’s more than a gem of truth in what we’ve said. The fact is that the subject of waterproofing is probably the single most contentious and complex issue in the world of motorcycle apparel. We get more questions, queries, comments and complaints about water ingress than we do about any other aspect of rider wear. There is, or has been, we fear, a mismanagement of expectations when it comes to the ability of biking jackets, trousers, gloves or boots to keep a rider dry. We may even unwittingly have played a part in this but, without doubt, the manufacturers, in order to create what might be termed a competitive advantage, have made claims that are, to say the least, misleading. In this short article, we’re going to try and set the record straight. We won’t be able to answer everybody’s questions, but we can throw at least a little light on the matter. The first point we would make is that if you want to travel from point A to point B and always stay completely dry, you should buy a car. If you ride a bike in the pouring rain for long enough, or hard enough, you will eventually get wet. Water runs off your helmet and down your neck. It will be thrown up from the road and up your jacket. It will hit your gloves and enter the sleeve. Or rise up your boot to your leg. It will find its way through zips and pockets. If the pressure of water is strong enough, and the duration of the ride is long enough, there is no garment out there that can guarantee to keep you totally dry. Any manufacturer who claims differently is lying. But the manufacturers don’t tend to lie (okay, some of them do!). Most use clever wording that, when unpicked, normally promises something less than the average motorcyclist has understood. The most common claim is that a material is backed by a membrane, like Gore-Tex, that is supposed to be 100% waterproof. From this, the manufacturers will then sometimes imply or suggest that their jackets or trousers are completely waterproof. The reality is that they are not, for all the reasons already outlined. And anyway, the standard test that is most commonly applied to certify a fabric or membrane as waterproof is exceeded by a factor of 20 when rain hits a motorcycle garment at a speed of 100kph! But even the best waterproof membrane is meaningless if the seams of a jacket are not taped with waterproof tape, or if the pockets are not also waterproof. And then there are the zips, the air vents, the collar, the sleeves and so on. So where do we end up? Well, as we’ve suggested, there’s no such thing as a jacket, a pant, a glove or a boot that can keep you 100% dry. But your chances of staying dryer for longer are almost certainly improved if you buy your clothing from one of the more technical brands out there. As a consumer, we admit that it’s not always easy to work out which brands are the real deal and which are not. And that’s because the cheaper, lookalike brands are often very good at copying the design and style of the more respected names. It’s not our position to say who you can trust and who you can cannot in this respect. You need to do your research. Visit the manufacturers’ websites. Visit some of the forums. Talk to dealers. But the highest priced gear isn’t always the best. People like Halvarssons, for example, produce gear that is far more technical than its pricing suggests. But beware, we would say, of anything that is too cheap. If the brand in question can always be found discounted, or being touted about by the George Whites of this world, or the other pile-it-high sellers, you can be pretty sure that you’re not going to be getting the most technical and reliable gear. It’s a cliché, we know, but if the deal looks too good to be true, it probably is. There is, after all, no such thing as a free lunch! Which brings us to another point. Waterproofing is not everything. As in so many things in life, motorcycle clothing is a compromise. The most waterproof clothing would not have a breathable membrane. It would keep water out with an impenetrable lining, but you would sweat horribly. In fact, perspiring on the bike can be much more uncomfortable than rain, especially when it cools down. The other issue is that most of us want a jacket and trousers that we can wear all year round; an outfit that works on a miserable, cold and wet morning, but also on a glorious blast down through France, Spain or Italy in the middle of summer. For such riding, you need unzippable vents. To keep air moving across the body, you open the vents. It’s vital if you want to stay calm, collected and cool. But in the winter, these vents are an inevitable weak point for water ingress. So, when you buy motorcycle clothing, think about how you might use it. Staying dry is something we all want, but the most fun is to be had when the sun’s out and, for those days, you need ventilation. There’s not a lot else we have to say. If staying dry is the most important consideration, you should of course avoid leather. A leather jacket can be a very cool thing to wear. I must own about half a dozen different leather jackets, all of which I love, but they’re for wearing on nice days when I’m not venturing too far from home. A leather jacket or a leather pant is about as much use in a rain storm as a tax return is to your average Member of Parliament. I’m going to close with a few words on boots and gloves. The basic tale is the same, but even more so. On a pair of boots, water will run down your legs. It will find its way through the zip or laces. And eventually, in heavy rain, the leather or Lorica will become so sodden that it will work its way through to your foot. After all, down there, near the road, is probably the wettest place of all. Gloves also take a hammering, although this depends on the bike and whether there’s a fairing, for example. Leather gloves will let water in most easily; whatever they’re lined with, so go for textile if staying dry is important. But don’t let us mislead you. Whatever you put on your hands, your fingers will eventually get wet. Which leads me to another fact about gloves that you may not have realised. Certainly, I didn’t until recently. If you turn on your heated grips when it’s raining, the warm air will suck water into your gloves, making them less waterproof. Think about it; it makes sense. Personally, there are times when I’d prefer to have hands that were wet and warm than dry and cold, but that’s a personal preference. Anyway, I thought you should know. I hope we haven’t confused you and made the subject even more opaque than it already is. But getting wet is really a rite of passage for motorcyclists. Some of the trips I remember most and still boast about are those where I get totally drenched and arrived at my destination cold, wet and miserable. Frankly, it makes the hot meal and beer at the end of the day even more welcome. If there was never any pain or discomfort, it wouldn’t be motorcycling. And there’s no way I would have swapped my mode of transport on any of those cold, wet and miserable journeys. However warm and dry I might have remained. I’m not sure that you should always expect to get wet on a motorcycle. And I’m not making excuses for sub-standard gear that doesn’t work. But when you’re on a bike, you are exposed to the elements in a way that you are not when you’re in the car. Be it hot, cold, wet or humid, on a bike you’re going to experience it to the max. That, after all, is why we love biking in the first place.
I cannot entirely agree with that. Remember that day at Donington Motogp when Rossi gave a masterclass on riding in the wet on the Gauloises Yamaha? I rode there that day 60 miles or so, stood out in the pissing continous rain watching the race and then rode home again. I had on a FT Goretex jacket and Alpinestars goretex boots. By the time i got home neither had leaked water at all. I took the jacket off and hung it up and it was like turning on a tap as they water drained off it.
I think they wrote it to cover up poor gear tbh, I have a Spidi jacket and trousers plus daytona boots they have never leaked you may get the odd drip down the sleeve but that's it, years ago I'd wear yellow rain mac over my dry weather jacket and yellow over trousers, worked well, before that plastic bags in boots was great, warm too...lol oh and mums marigolds mmmm nice in pink Ha HaHa
Does seem a bit 'not my fault guv, they all do that..' Thanks for the nixwax link, going to get some and coat by kit and see how it goes.
Nikwax is the dogs dangly bits. I cleaned my leather jacket up today with their leather cleaner. Two months and probably 1500 miles of dirt and flies and it came up like new once again.
