999 Fairing Grommets
Discussion in '749 / 999' started by Old rider, Mar 24, 2015.
  1. Had a torn grommet on the left side, the one which the metal peg on the side fairing locates in.
    I removed the grommet and replaced it with the torn bit on the inside, so the outer bit which the peg locates in is now perfectly intact.
    I then smeared white lithium grease on the rubber on both sides of the bike.
    The result is that both side fairings are now enormously easier to refit than they were - highly recommended!
