The fan's run constantly with the bike switched off, the only way i can stop it is to pull the BBS fuse, are there any relays that control the fan or is the BBS unit the likely culprit for this? I did try a couple of other fuses but only the BBS fuse stopped the fans, ideas would be great, cheers.
Download the owners’s handbook from the Ducati site. There is a wiring diagram at the end of it. You will see there are no relays. The fans connect to the BBS.
