Knowing that my RH fork leg is slightly losing oil and that I just replaced the calliper seals, I was surprised to see the amount of “liquid” on my RH side of the front wheel and tyre.RGV250 not my Duc. I deeped my finger in the liquid, smelled like nothing else before. So I smelled an open bottle of brake fluid..was similar but not the same. Couldn’t decide if fork oil or brake fluid or mixture of both. Anyway, I wiped clean the fluid then washed it with clean water just to be on the safe side. After 5 minutes my Alsatian male walked in and re-marked the spot, he looked a little bit offended by my behavior…..So glad I did not taste it.
