Oberon Clutch Slave cylinder black. Will make your clutch lever action nice and light. It is anodised black. Item is not used but not in box. Has two small dings in anodising but few seconds on road will make it disappear they are so small. Will fit most Ducati models, I think anything dry clutch prior to 1098 as long as it has the longer push rod as I lost the spacer adapter that would make it fit to early models. You could get this and the longer replacement pushrod which is about 15 GBP. Price to sell 55GBP plus postage (RRP is smidge over 90). As in title FCR's 41 for sale. Will fit carbed monster, SS and if you got time other They are the railed one's to be fitted with air-box. For sale: FCR's 41 linked (Railed) K&N air filter to fit Monster 900 Cut open air-box cover Two throttle cables Throttle assembly but it is damaged. Usable and working ok until one finds replacement. I also have two velocity stacks (if you want to ditch air-box) that came with it but at the moment cannot find them. Will add them if I find them. Price is £600 plus postage, RRP for kit like this is £850. 2002 900SSie speedo cable and drive £15 plus postage. Powder Coated Black Top & Bottom Yoke from 900SSie. Price £90 plus postage A 900SS ie stand powder coated black for nice look. Comes with opening sensor. £50 plus postage. Rider and Pillion pegs plus controls powder coated black. Will sell as set for £80 Separate Rider pegs and controls £50 Pillion Pegs £30 Ducati 900ssie frame. It comes from a 2002 model that I am braking. It is a category C frame that comes with V5, licence plate and is sorned. Frame is straight and in good working order. Bike had a right hand side slide so right hand side front sub-frame mount has cracked. It was welded back in place and works well. Frame was powder-coated in Ducati red in preparation for rebuild but plans changed. Price 100 plus postage or make me an offer 900SSie front subframe (light/dash bracket) powder coated red. Price 50 plus Postage. (or make me an offer).
Hi Gaz. Yours is the earlier model that would need later longer push rod or spacer adapter I mentioned I lost. Will have a look in garage over the weekend again for it as should have in total 3 but could not even find one Grrr. Will get back to you.
