1299 Fixed Suspension Settings
Discussion in 'Panigale' started by Kaspar, Oct 2, 2019.
  1. does anyone have any fixed suspension settings for the 1299s .
    I’m at portimao and I’ve got the dynamic on its hardest and it feels to soft. Thought I’d try dynamic. Doing 2:03’s and the front end is diving to much and could do with stiffening up
  2. this is my saved fixed settings from the 1299s
    Front- C 10
    -R 14
    Rear – C 6
    -R 8
    SD- 12
  3. That’s the standard settings. I’m bottoming out on those settings.
  4. then i haven't updated my last suspension notes, sorry,
    but it will be not far from that with a little more compression Circa 8 then
    this is with a 100n rear spring and a 100kg (dry) rider
  5. Depends how heavy you are. Are they actually bottoming out? I ask as the multi was the same with skyhook: regardless of circumstances it dived as much but that last 20% of travel seemed to firm so it never bottomed out. Assume you have put a cable tie on it?
  6. Yes bottoming out. Cable tie is going all the way down.
    I’m 80kg in my boxers. Not heavy .
  7. That’s heavy for ducati tbh. Is wind preload up as far as poss and see what happens.
