1199 Flapper Servo
Discussion in 'Panigale' started by PCRR, Jan 23, 2017.
  1. hello all.
    can anyone tell me where servo is for flapper valve. I have removed cabled from exhaust valve but wanted to disconnect from servo too.
  2. Hello
    Take off the lower fairings and it is located at the front of the bike. There is a great video on YouTube on fitting termi's on a 1199 that talks you through fitting the termi's. this includes the removal of the flapper valve motor unit. Basically lower fairings off. I took exhaust off as was putting on an sc project silencer. Clip off a few cable ties. Un plug the motor unit. Un do 4 screws holding the servo motor to the bike these are right at the bottom at the front behind the wheel where the lower fairing is. There is also a metal guide for the cable from the motor to the flapper valve. This need to be undone and then replaced. Easily done. If you don't have a bike lift then lots of lying on you back messing about.
    Hope this helps
    James
  3. Don't know how to attach the link but put in google 'fitting termignoni on 1199s' . It's dated 18 march 2013. 10 mins 31 long.
  4. Thanks JAM 35
  5. Do you need the plug in part to fool the ecu in to thinking servo is still there ?
  6. No you won't get an error on the dash but if you plug in a ducati tool it will show the missing servo.
  7. Thanks If you did use the part would it not show on the diagnosis machine when plugged in during a service ?
  8. I've done all that removed it all it was just about the fault code when it goes into the dealer
