I've just bough a RH foot peg for the 848 off ethief; unit was advertised as coming off a 1098 and was attractive as it's a non slip variant... its just turned up and is the dogs nads... Its a Rizoma unit; were these standard on any 1098s, or pure after market... I'd like to get hold off a matching LH one... Cheers, Bob
The 1098S has the same pegs as the 848, the slippy ones. Rizoma's are aftermarket in this case. The 1098R ones are grippy ones, like the Rizoma's. The DP ones are to.
As most things are. But I don't think the Rizoma pegs are all to expensive. If I remember correctly they're € 69,- for a pair. I've been toying with the idea to fit them to, but then I'd want to adonise the rear sets black. Adding it all up and combining it with the scratches and use marks that are on the current set, a new rear set will be better and cost only a bit more.
