Hi Guys - I'm selling my HM Strain Gauge Quick Shifter System for PCIII. Its been used once and comes in the original box with fitting and calibration instructions and is as new. I'll also include a disk with the Power Commander Enabling Software which doesn't come with it as standard and which Dynojet wont sell/give you unless you buy their QS System!, which you need to tell the PC Unit that a QS System is fitted. The system is a Road Shift Pattern and not a race shift pattern. The System is easy to install as it just plugs in to the PCIII and you replace the original shift rod on the gear linkage with the HM one - which is the correct length for the Ducati - and as its been on my 998 should be pretty much already set up for you. The unit will fit and work with any Duke fitted with a PCIII Power Commander. RRP is upwards of £325 - will take £275. PM Me for any more info Cheers Gav
