Free Diagnostic Software For Siemens M3c Ecu
Discussion in 'Technical Help' started by chrisw, Jan 15, 2015.
  1. It's been a long time in development but JP has finally released his diagnostic software for the M3C ECU. It is Windows PC based software.
    Download page
    As with JPDiag you will require a licence to get it to fully operate.
    You will need an ELM327 diagnostic either USB or Bluetooth and a DDA adaptor. The DDA adaptor can be bought from Ducati 4 Pin Multistrada CAN Diagnostic Connector Adaptor [LEDUCC16ADAP] - £14.99 : Lonelec, Fault Code Readers & ECU Diagnostic Equipment
    I have been told that the new Scrambler uses the M3C ECU.
  2. What does the 1199 pani use ?
    Any idea of cost for full use of software?
  3. The 1199 uses the Mitsubishi ECU
    JP did release an unlimited version of the IAW5x software for €100 but I have no idea if he intends to do this for the M3C.
  4. Ah ok cheers mate
  5. Does this work with the 796 hypermotard?
  6. Yes
    This is the M3C ECU
  7. Thought so but I'm a bit thick so thought I'd ask.
  8. hello my man. I know this post is old but I have a 2004 749 Ducati with a Siemens ECU. Might you know if the kit you mentioned would work with my Bike - I need to reset my TPS
  9. Ducati 749 uses the IAW59M or IAW5AM ECU
    You can use JPDiag.
