Fried Ecu
Discussion in 'Technical Help' started by Ryan bligh, Apr 24, 2021.
  1. Hi all iv managed to frazzle my ecu.
    Fan on ect.earthed the ecu but cant access use diag port to reset tps.
    Advice very welcome
  2. If you are looking for a replacement Avanti race parts sorted me out when mine failed. They offer a few options. Exchange, repair, replacement and custom mappings if desired.
  3. What bike? Guessing 999 from your profile.
    ECU model?
    I take it you have inverted the fly lead polarities?
    Try this, connect the Fiat adaptor by itself to the diagnostic port. Connect the -ve black fly lead to a good earth on the engine or frame. Turn on ignition. Do the fans stop. If the do then identify what would be the middle wire on the 3 way superseal diagnostic connector. Tap a wire into it and run the wire to the -ve (negative) terminal on the battery. This should sort the problem.
    A second hand ECU may be the best solution. I can help you with any remapping/immo flashing.
    • Useful Useful x 2
