Help needed, my 2006 749 has failed its MOT on a leaky front brake master cylinder and the garage says that brembo don’t do a repair kit, is this true, I have looked on eBay etc and can’t find anything, can anyone help me....
I would be surprised if Brembo had special seals made for their cylinders. I would strip it and see if you can find seals from some other cylinder. They might even have a manufacturer or number on them.
Is it for a PR18? - people used to post up the equivalent KTM part numbers, but not for a while. https://www.dirtbikexpress.co.uk/search.php?search=brake+master
Hopefully if we keep posting, someone will turn up with the info you need Mark, KTM could be your best bet when you know the equivalent - have you managed to confirm what type of m/cylinder? is it a Brembo PR18? @Denzil the Ducati @Derek @Sev.
Apparently so, I assumed that if they did brembo caliper kits they would do m/cyl kits as well. It seems I was wrong.
Powerhouse sell mastercylinder kits on ther ebay site http://www.ebaystores.co.uk/Powerho...5999017&_sid=1008591237&_trksid=p4634.c0.m322
Thanks for link turbod, sadly no Ducati (or KTM) kits listed. I know there was a KTM that used the same master cylinder as older Ducati but i have a feeling that there isn't a KTM that uses a PR18, I could be wrong.
