1200 DVT Front Brake Resevoir Leaking
Discussion in 'Multistrada' started by Lord Farquaad, Jul 30, 2019.
  1. So my DVT was in for service a couple of weeks ago and they pointed out that the front brake reservoir was leaking from the 3 o clock position as you look from above.
    It went back in today and they replaced the seal.
    After the ride home I can see it’s still very slightly leaking from the same spot.
    Given your experiences is this likely to get much worse (ie needs sorting now)? Or can I wait a bit to get it sorted? (It’s under warranty so I’m not paying myself).
  2. Get the optional ducati metal caps, job done.
  3. Take it back to the dealer as soon as possible & fix it would be my advice.PDQ
  4. “Again”!? ^
  5. Still leak from the Alloy caps on occasions, just a slight weep, on both my 1200 DVT and 1260, mind you that's using the same caps on both bikes. I'm sure a mod came out for this issue some time ago though :thinkingface:.
  6. At least I got back from the dealer (the long and twisty way too) before the rain. Else I wouldn’t have been able to detect any leak (other than my crotch).
  7. "They all do that sir!"
  8. Careful replacement and cleaning of the seal is the answer mines done it a couple of times. But dealer should know that and should sort it.
  9. Don’t fill oil to the brim. Keep it in the middle. That’s my answer.
  10. yes, a good start. ^:upyeah:
  11. And dont over-tighten the screws, as that makes it worse.
  12. When mine started leaking, I used the opportunity to replace the brake fluid on all reservoirs as the clutch reservoir was black within only 1 year of use.
    Cleaned and dried seal and cap, leaving the levels between min/max. Very hard not try to tightening up the screws "a tiny bit more". And this "tiny bit more" made it leak again in a couple of days. Did the job again, without replacing the seal, just cleaning and drying it, this time used a small screw driver and not even held it from the handle, just spin by two fingers. Thought: "This won't hold it!". But it did and no leaks since last year.
  13. The 2 screw type fixing on these reservoirs is awful.!
    Soon as you tighten them they cause the cap to go out of shape.
    Why they didn’t use a screw type top is beyond me.
