Front Brake Switch On 848 Evo
Discussion in '848 / 1098 / 1198' started by Pagey, Feb 8, 2015.
  1. The switch on my 848 front brake has broke and is causing the brake light to stop on permanently does any one know the procedure to disconnect and fit a new one I ve followed cable back to behind headstock/under tank , so was wondering which way to get to it
  2. The mcro switch simply levers /pops out of the M/C.
    It attaches to the main loom with two bullet connectors, not sure exactly where, sounds like you may have to remove the tank.
