Extract from the Brembo catalogue...... Part DBFFSS7591G Compatibility Direct replacement for the following models: This front floating disc rotor is constructed from420 stainless steel, with a gold anodized 6061 Aluminium alloy centre hub forlight weight. The shape of the disc ensures good heat dissipation under heavybraking sessions, reducing brake fade, minimising warping, and ensuring rotorlongevity. The slotted rotor ensures water and dirt are dispersed quickly whenbraking. Features: - Laser cut, high carbon stainless steel hardened and tempered to ensure lowpad and rotor wear characteristics. - Suitable for left and right hand fitments Dimensions Outer Diameter: 320mm Inside Diameter: 64mm Bolt spacing: 80mm Thickness: 5mm Weight: 1.47kg Installation These are a direct replacement for the original rotor, simply remove existingrotor and install the new one. Aprilia 125 MX Front 04-06 125 RS Front 92-05 (Radial Caliper) Front 06-07 125 Tuono Front 04-06 SL 750 Shiver Front 07 NA 850 Mana Front 07 ETV 1000 Caponord Front 01-04 RST 1000 Futura Front 01-04 RSV 1000 Mille Front 99-04 RSV 1000 R Front 04-08 RSV 1000 R Factory Front 04-08 RSV 1000 R Mille Front 00-03 RSV 1000 R Nera Front 04 RSV 1000 R Tuono Front 04-07 RSV 1000 SL,SP Mille Front 00-01 SL 1000 Falco Front 00-04 Benelli 900 Tornado TRE Front 04 900 Tornado TRE LE Front 04 900 Tornado TRE RS Front 04-05 1130 TNT (RS, Cafe Racer,Titanium) Front 05-06 1130 Tornado Front 06 Cagiva 125 Mito 2 Production Racer Front 94- 125 Mito EV Front 96-07 125 Planet Front 97-02 125 Raptor Front 03-06 125 Super City Front 91-00 500 River Front 99 600 River Front 94-98 Ducati 400 Monster Front 01- 400 SS Junior/Supersport Front 92- 600 Monster Front 00-01 600 Monster Front 94-99 600 Monster Dark Front 98-99 600 SS Front 91-97 620 Monster Dark Front 03-04 620 Monster i.e. Front 02-03 620 S Monster i.e. Front 02-04 620 Sport Front 03 748 Biposto Front 95-98 748 Biposto Front 99-02 748 R Front 00 748 S Front 00-02 748 SP Front 98 748 SPS Front 98-99 750 Monster Front 96-97 750 Monster Front 98-01 1100 Griso Front 05-06 1100 Sport Front 94-99 1100 V11 (all models) Front 99-06 1100 V11 Breva Front 05-06 1100 Hypermotard S Front 07 998 Monster S4R Testastretta Front 07 998 R / S / Biposto Front 02-03 1000 Monster IE Front 03-05 1000 Sport Front 06-07 1000 Sportclassic GT Front 06-07 1000 Supersport DS Front 03-06 1100 Hypermotard Front 07 750 Monster ie. Front 02 750 Monster ie. Dark Front 02 750 Sport Front 00-02 750 Supersport Front 91-02 800 Monster IE Front 03-04 800 Sport Front 03 800 Supersport Front 03-04 851 Superbike Strada, SP Front 90- 851, Replica Front 88-89 888 SPS, SP 5, Strada Front 91- 900 MH900 e Front 02 900 Monster Front 94-99 900 Monster ie Front 00-02 900 Sport Front 02 900 Superlight Front 92-98 900 Supersport Front 00-02 900 Supersport Front 91-99 907 I.E. Paso Front 92-93 916 Monster S4 Front 01-03 916 Sport Touring ST4 Front 99-03 916 SPS Sport Production Front 94-00 916 Strade Biposto Front 94-00 944 Sport Touring ST2 Front 97-03 992 Monster S2R Front 06-07 992 Sport Touring ST3 Front 04-07 996 Biposto Front 98-01 996 Monster S4R Front 04-06 996 R / S / SPS Front 99-01 996 Sport Touring ST4S Front 02-06 KTM 990 Super Duke Front 05-07 Laverda 650 Ghost Front 96-97 650 Sport Front 95-01 750 S Formula Front 98-01 750 Strike Front 98-01 Moto Guzzi 750 Breva V 750 IE Front 03-07 750 Nevada Classic IE Front 03-07 850 Breva Front 07 940 Custom Front 07 1000 V10 Centauro Front 97-01 1000 V10 Centauro GT Front 98-99 1000 V10 Centauro Sport Front 98-01 1100 California EV Evolution Front 97-01 1100 California i Jackal Front 00-01 1100 California Special Front 99-02 Yamaha TDR125 (Italy) Front 89-93 TZR125 RR Front 94- FZX250 Zeal Front 91- TDR250 Front 88-92 TZR250 R,SP Front 87-92 SRX400 Front 91-96 SRX600 Front 90 SZR660 Italy Front 95- FZR750 Genesis Front 86- FZR1000 Genesis Front 87-88 FZR1000 R (EXUP) Front89-95 XJR1200 Front 94-98
Tsk! You'd have thought Brembo would know their own gear..... For anyone that might like the Brembo motorcycle catalogue for reference, it can be downloaded here: http://www.yoyodyneti.com/images/PDF/Brembo-yoyodyne_catalog.pdf
Be warned that early carbed SS wheels are not interchangeable with later carbed SS wheels with regards to the speedo drive components. Even though axles and bearings can be changed, the drive unit, seal and drive washers in the hub are different..... You can tell the difference by looking at the brake disc locating rib around the edge of the speedo drive housing in the hub.....On early wheels the rib is about 6mm wide, later wheels it is about 4mm. However, the same rib OD means the discs are interchangeable.... AL
