999 Front Rotor Weight: Oem Vs Ebc Vs Brembo
Discussion in '749 / 999' started by TheJackal, Feb 3, 2022.
  1. No unfortunately I don't have the weights myself but I'm asking to know if anyone does :)
    Back when I was a wee bit younger and was racing my 1000 K7 I went with Brembo Supersport fully floating discs and found they were quite a bit (don't have the exact numbers now) heavier than OEM. Might have been down to the fact they were 5.5mm thick on the brake track.
    Does anyone know the weight of each OEM 999 disc and the equivalent from EBC (XC ?) and Brembo ?
  2. To answer myself, research has come up with:
    Ducati 999 OEM - 1,675 Kg
    Galfer Wave - 1,325 Kg
    EBC VR622 - 1,484 Kg
    Shame the Galfers don't come in gold :(
  3. You might already know this info: 320mm 6 bolt (duc 916 fitting) Brembo Oro's weight ~1600g (1.6Kg) suspect the same ORO's in 999 (5 bolt) fitting are similar. These are also unfortunately black centres.
