FS - 996 / 916 / 748 race and road parts
Discussion in 'Parts, Accessories & Clothing For Sale' started by Desmophil, Jun 5, 2012.
  1. Still for sale the following parts. cheaper prices.
    See below for pictures.
    Fancy parts:
    - Pierobon front subframe, can fit standard clock or Digit dash - new price £120
    - 998 RS wide track adjustable mag yokes - £1,500
    - 16.5" wide track wheels (3.5 / 6.25) - 5 spokes - refurbished in stain black (crack test, etc. done then by Griff in Bristol). The finish is not perfect with some marking on spokes. Includes Dunlop slick tires used for one trackday. £650
    - Dymag rear 16.5" wheel with big hub. Gloss black, clean, Wet tire mounted on it. £200
    - Brembo 290mm wide track front discs - £130
    - Brembo 320mm road fitment race discs (very clean) - £350 - SOLD
    - Billet race caliper hanger - £150
    - Spacer to mount RS big hub rear wheels on to standard axle - £100
    - Slipper clutch - Ducati Performance - ball bearings, basket a bit marked - £300
    - Sil Motor slip on exhausts - £200
    - Ohlins steering damper - £170
    - Titanium front standard axle - new, never fitted - £80
    - AP thumb brake (brake lever modified) - £250
    Standard parts:
    - 999 throttle bodies / airbox / with injectors - £150
    - Standard 996 dual injector throttle bodies including bell mouths, TPS, subloom, injectors, etc- £120
    - Reverse shift pedal - £30
    - Standard clip ons - pair £45
    - Swingarm black powder coated with chain runners and hub - £150
    - Standard rear axle with disc and standard caliper hanger - £50
    - Race nose cone - fiber glass - number board - £40
    - Carbon fiber mudguard, small crack on bottom, does not affect fitting - £40
    - Carbon V piece ok condition - £30
    - Red tank - good, small paint chip, old style Ducati logo, NO pump, no cap - £130
    - Water rad - tatty - £15
    - 45mm clean system - £50
    - Standard 1.6 ECU - £50
    - Standard coils + plug leads £40
    - 748R JHP airfilter - £70
    - Suspension rocker cast - standard - £25
    Collection from South London
    Shipping at cost
    Can supply photos
    Payment by bank transfer - Paypal OK (fees paid by buyer)
    Some parts have now gone on ebay, I will stop those auctions if no bid.
  2. Photos below
    Tank - cap not included
    Swingarm
    290mm discs
    SIL MOTOR exhaust
    45mm system
    Reverse shift pedal
    Throttle bodies
    Rad
    Pierobon Subframe
  3. AP Thumb brake
    Spacer for fitting Big hub wheels to road axle
    Slipper Clutch - DP
    RS small hub Billet Caliper hanger
    (fits standard arm - spacing for race calipers Brembo or Ohlins)
  4. carbon mudguard
    V Piece
    V Piece with crack
    Nose cone
  5. Do ye still have the Ohlins steering damper ?
  6. That steering damper is long gone.
    I have looked around and only have one which will go on to my 996
    But I thought I had a couple so I need to look harder probably.
  7. I'm looking out for one for my 748 , cheers
