I am putting much of the below on ebay, but if interested, please make offers. Photos available in my photobucket available at: 996 Part sale pictures by desmophil - Photobucket 748 Frame - £250 Frame is still on US title as previous owner did not bother registering it in the UK (used on a track bike). Import paper available. Frame powder coated in Ducati Red. Frame numbers have been left showing as this is now scrutinized even at track days. Frame can be UK registered by going through the Motorbike Single Vehicle Approval. As the papers are available you would end up with the relevant year registration (and not a Q Plate). Black powder coated Swingarm - £120 Recently powder coated. Selling with hub, chain sliders, new bearings have been installed, front rubbers in place. Additionally, choice of 2 axle with rear disc and choice of 2 caliper hangers £40 for each axle / disc £15 for each caliper hanger Ohlins rear shock - £370 Standard ohlins rear shock with remote race preload adjuster. Makes the adjustment of the preload so much easier with a simple screwdriver. Suspension rocker - £20 plain standard Standard throttle bodies for 996 - £100 Standard bodies, 2 injectors per cylinder, standard loom for 996 with parallel firing of injectors as controlled by 1.6 ECU (should fit other models like 916 if you wish to upgrade to dual injectors). I can throw the manifolds in with these. Standard throttle bodies and airbox for 999 - £120 just standard 748 R throttle bodies bored to 54mm with spacers for fitment to 996 as performance upgrade - £250 This will allow performance upgrade with shower injectors to 996 engine. Note - you will need the bigger airbox with injectors inside the airbox for this set up. Coils + leads to spark plugs - £40 Pair of standard coils with brackets for 916 / 996 with HT lead to spark plugs. Pair of Sil Motor race slip on exhaust. - £170 Nice open carbon pipes, look better in my opinion than Termis due to having shorter pipe ends. Sound pretty good too. Rest of the 45mm system also available for £50 (quite clean) first refusal to whoever buys the end muffleurs. Standard 916 tank - £120 Bare tank - clean as can be seen in pictures. Couple of paint blemishes but otherwise OK. No pump. Magneti Marelli 1.6 ECU for 916 - £40 Eprom was supplied by Louigi moto for 916 with open 50mm system. Titanium front axle - £80 Will fit the 748 / 916 / 996 / 998 series as well as STs, some Monsters, etc. 998 oil cooler - £30
Quick update: 748 Frame - £250 - available Pierobon front subframe - sold Black powder coated Swingarm - £120 - available axle / disc £40 - drilled one gone other available Caliper hanger £15 each - available Ohlins rear shock - £370 - available Suspension rocker - £20 - available Standard throttle bodies for 996 - sold Standard throttle bodies and airbox for 999 - £120 - available 748 R throttle bodies bored to 54mm with spacers for fitment to 996 as performance upgrade - £250 - available Pair of Sil Motor race slip on exhaust. - Sold 45mm system clean £50 - available Standard 916 tank - £120 - available Magneti Marelli 1.6 ECU for 916 - £40 - available Titanium front axle - £80 - sold 998 oil cooler - £30 - available
ecu is the ecu still available ?is it the whole unit also do you no if it will fit a 2000 748 it appears mine cooked itself after finding out the battary was pushing out 18 v at high revs thanks if you could e mail your reply il be gratefull nick [email protected]
998 oil cooler? Hi, Is the 998 oil cooler still available? Can't see the pics, but what sort of condition is it in (and assume is also ok for 998s?) Thanks, Pete
Yes cooler available. Condition is not great for the fins hence cheap price. But with some patience and some twisers you could fix that. Might even have the hoses (additional) Of the above the following is still available. I can take offers especially if you collect the bigger items. Just don't take the mickey with stupid offers as i get wound up. 748 Frame - US title, fresh powder coat, frame numbers still visible can be UK registered after a MSVA- £200 Pierobon front subframe - appearsto have been bent a little, probably to mount on road nose cone (RS is narrower). Includes bracket to mount digital dash. (standard clocks also fit). Make offer. Std rear axle + disc - make offer Caliper hanger £15 each Standard throttle bodies and airbox for 999 - £120 748 R throttle bodies bored to 54mm with spacers for fitment to 996 as performance upgrade - £250 998 oil cooler - £30 Plenty odds and sods Also breaking my 998 RS Chassis, Very tuned S engine
