Fuel act stabilliser ?
Discussion in 'Lounge' started by peter james, Sep 18, 2012.
  1. #1 peter james, Sep 18, 2012
  2. Looks like a bird feeder with some Blackpool rock in it :smile:
  3. Hmmmm...
    Dyno tests would prove if its actually doing anything for power or not? :upyeah:
    Would be a handy addition in something old like my 400/4 - designed to run on leaded petrols, unleaded petrols will knacker the valve seats, I have to add lead-replacement/octane booster Voodoo juice to prevent this...
    Would be good if it does what it says on the can??
  4. Remember something similar when 4 star was being phased out, back then it was supposed to gradually release a lead substitute to save your valve seats. I assume you just stick it in the tank?
  5. [​IMG]
  6. "Re-grows the hair you are losing, removes the unsightly hair you don't want ... and it'll cure your asthma, too!" :biggrin:
  7. Or try this one, a rather similar tin-based fuel catalyst which has been in production much longer. I have used it myself successfully.
    BROQUET Fuel Catalyst home page
  8. Pete, this was the one I was thinking about in my earlier post!
  9. if it's any good I'd give it a go but I only run enough fuel in my tank to get me up the hill ,probably around 3l ,it would be banging and rolling around in the tank :rolleyes:
