On my 2008 1100s hyper when I disconnected the fuel pipes to change the filter, I thought it was obvious which went where, but now I'm not sure. How do you tell which connector goes to out and which to in?
So is the pressure regulator in the pump housing or on the throttle bodies? I'll go an have a look with a torch and try and work it out
Well I had a good look about and can't see any pressure regulator on the fuel line, it just goes through both injectors and back again, so presumably it doesn't matter which connector goes where.
Hi. You don’t seem to be getting much help. I don’t know about your bike but there was a very recent thread on the same subject which cane to your conclusion. Do a search?
Thanks for the link, I'd seen that post and where as the 916 etc have a very noticable pressure regulator in the pump base the hyper doesn't, hence my confusion!
Go with your gut. Surprised no one has been along to help. Suspect it’s coz the other thread covers same thing. Just different bike.
Sorry - even though ive got one i dont tend to look in here that much....i promise to in future - i would say with the other poster that they tend to fall in the right place...
