So if my Garmin is wired directly to the battery in its cradle turned off will it take current to charge itself. Don't want a none starting or hard to start morning to worry about. My mind says it won't but doubts are flying around my head.
It will take current. Taking the garmin out when not in use will reduce that drastically, does the cradle have an LED light?
Best bet is to get a relay for a couple of quid and wire that in. That way it only powers with the bike on.
Given that I'll leave messing and just not leave it on overnight when using on the hols Thanks all Cheers
Would a switch be a better bet, and would it not take current if in the off position? Thinking of doing this for my rear view camera.
If it's switched off but connected, the rechargeable battery would still take current, I'm sure but very little.
Oops, sorry, I think maybe I didn't read/understand the question properly. I thought 'off position' was referring to the unit, not a relay or switch. Duhhhh...
Isolate it with a switch to be on the safe side. I left my Garmin connected on my R1150R and it drained the battery within a week (big battery at that!).
You are asking a very similar question too: "Will the electricity leak out of my wire if I don't tape it up?" ;-)
Agree, if you're wiring a switch you should just wire a relay instead. Much better as you will inevitably forget the switch and park your bike for a week leaving your battery dead. Sent from my iPhone using Tapatalk
