1200 Garmin Zumo Mounting
Discussion in 'Multistrada' started by Speed_Triple, May 12, 2014.
  1. Anyone prepared to divulge the best way to fit a Zumo 350 to a Multi - bearing in mind the U-clamp supplied is to short the use in conjunction with the bike's oversize handlebars.
    Could look for a longer clamp I suppose but the nearest hardware shop is rubbish and I'm looking for a quick fix!
  2. quickest way - change a bar clamp bolt for a ram ball mount.
    best way (imo) - use a navihalter.
    If you don't like the nav up high, buy a clamp that puts it on the bar clamp area.
    Do a search, there are loads of posts about satnavs.
    or go have a look on motorcycleinfo.
    Hope that helps :)
  3. Here's my 350 mounted,
    Since this picture was taken I,ve angled it a bit better so its easy to look at with a quick glance. I read the following link and bought the mounting kit from the US. It was the best solution for me and very happy with it.
    MTS1200 DIY Mods > MTS1200 GPS Mounting (3)
  4. Touratech mount in conjunction with the Navi Halter works for me, keeps the Nav up high and in your line of sight.
  5. + 1 for Navihalter
  6. Ram mount handlebar clamp bolt plus a short ram arm works fine for me, and is much cheaper than going with any of the bespoke holders.
  7. +2 Navihalter. Way better than the handlebar mount IMHO. And you have the option to use a tank bag if you wish
  8. IMO the Navihalter is one of the best options!
    I've also used a Telferizer ball mount replacement bolt, which was good, but does limit the use if you prefer, of a tank bag.
    The handlebar clamps are totally U/S IMO, they look messy and clumsy, however, you pays your money, you makes your choice. Each to their own depending upon budget and preferences.
    :D
  9. Navihalter, works well.
  10. very satisfied with my mounting bracket from: BikePenR
  11. [​IMG]
    My set up. Keeps the nav screen clear of the clocks plus it makes it easy to operate and in line of sight.
  12. +1on that
