Hi Guys, when I change down, the lever stays down and does not return to the original starting possition. Started happening on the way to work this morning. Anyone else had this, can I fix it or is it a bikeshop job?
I had this a couple of times but only stayed down momentarily, re-greased the pivot with copperslip, not done it since, maybe see if this helps
Thanks, hope that works but it's not a momentary thing, it stays down perminently, will give it a go though, cheers.
