Gear Ratio Change
Discussion in 'Streetfighter' started by Cole Trickle, May 20, 2024.
  1. Morning all, I'm headed off on a road trip in a few weeks and wanted to make the gearing a little longer to make the motorway cruising easier.
    My local dealer said if I get a front sprocket one tooth bigger the bike would through a fit and enter limp mode.
    Anyone have any experience of this?
    Thanks Ed.
  2. Are we talking V4 Streetfighter or one of the older variants ?
    The V4 would probably be fine, just need to do a "tyre calibration". Though I'd be surprised if you really needed the difference ? I've not noticed it "over-reving" in 6th... the few times I've tried it on the motorway.
  3. At 75mph its reving around 6500rpm. Thats quite high for a long duration I think. The change might also help the horrendous mpg (I dont care but the people I'm with will)
  4. Mine is showing 75 at 6000 maybe new versions have different gearing?
  5. Mine is the same with a '23 model.
  6. According to the manual the Taiwan version has different gearing. 16/42 as opposed to 15/41
  7. I think that would mean the Taiwan version would actually have lower revs at the same speed, rather than higher like the OP, if my maths is correct.
  8. Apologies, I didn’t make it clear in my post that the Taiwan gearing is lower. The point I was trying to make is that it would appear to be possible to run different ratios on a Streetfighter.
  9. Gotcha!
  10. Just remember to run the "tyre-calibration"... Think I might already have mentioned it, but that's all it needs :)
