Diavel Gen 1 & 2 - Exhaust And Rear Shock Question
Discussion in 'Diavel & XDiavel' started by Carbon749, Jun 2, 2020.
  1. Hi,
    I will shortly be listing a few parts from my Gen 2 carbon for sale, but, before I do, I wanted to see if if anyone can advise if the full termi from a Gen 2, will fit a Gen 1 as well? the pictures look the same, but the part numbers are different due to different ECU / up keys etc.
    Based on the answer to the above, I also have a full stock system from a Gen 2, so if a full termi will fit, I assume the full stock will also fit.
    Would an ohlins from a Gen 2, also fit a Gen 1?
    This is not a listing for the parts and I will not take offers on the above via this thread, I will update my subscription and list the items for sale that way.
  2. The Ohlins web site shows one rear shock for the 1200 Diavel from 2011 to 2018. The Termignoni for the first generation model used a replacement ECU whereas the second generation used an upmap key. The mechanical fit could quite possibly be identical as I am not aware of any differences in the external engine parts between the two. Andy
