Geometry Question
Discussion in 'Suspension help' started by Noste500, Jun 20, 2021.
  1. 1299 bike . I want it to turn in quicker .
    Are you guys running longer shock length or dropping yokes down on forks a tad ?
    ( to achieve the above )
  2. You could raise the ride height or drop the forks (but watch for rad clearance under heavy braking).
  3. The lower rose joint on the Panigale V4S Ohlins rear shock, can be unscrewed to increase the rear ride height by a small amount. I increased mine by 5mm. If your 1299 has an Ohlins, it might be adjustable too. Did I feel any difference ? Did too few laps of Donington to tell but really need to wait for Almeria in October as I’m much more familiar with that track. Andy
  4. Pretty sure my Ohlins rear has ride height adj
    So will spin that . also need 2 more turns of preload coming out of front so that will help also
    Might need to play with front tyre pressure also
    Cheers
  5. The 1299 Ohlins shock does not have ride height adjustment the same as the V4 as the shock is horizontal
    There is adjustment but I can’t remember how but I can check the 1199 in my garage at weekend
    Easiest way is to have more fork showing you should be able to feel a difference from around 2-3mm but also take note of what tyres you have as a 200/55 will sit around 5 mm lower a 190/55 more like 8
    I swapped from Pirelli 200/60 to Bridgestone V02 200/655 on my V4 which sits 5mm lower so I had to raise 5mm just to keep it the same
  6. I’m in Almeria in Oct with both my V4 and my 1199 so come and say hello if it’s the 1-4 Oct trip with FE
  7. Can’t remember the exact dates but we are there with BBS Eurotracks, a small independent in West Berks but thanks for the invite. Hope you have a good few days. Andy
  8. Cheers and you
    I live borders of Berkshire Hampshire and always looking for new organisers to try
